I am looking to calculate the gain of this single Jfet amp stage. I found this previous thread:
http://www.diyaudio.com/forums/soli...ate-gain-typical-small-jfet-preamplifier.html
and using the simplified version of John Curls calculations: Vg=R(1)/{R(2)+1/Gm} or R(1)/R(2) approximately
R1/R2 = gain
I find that we have about 6K/12K = gain of 2 or 6db Correct? seems to make sense.
Zc
R1/R2 = gain
Zc
Yes, 6k in the source and 12k in the drain would yield you gain of 2 when output is taken from the drain and loaded with a reasonably high impedance (10k would be fine).
Remember that the output will be inverted with respect to the input, so you may want to include another stage or simply live with it.
This is actually part of a GK 1001RB bass amp. This Jfet is in there for flavor only from what i gather. there is an op-amp before and an op-amp after so this Jfet really doesn't DO anything other then overload and change the sound. But once i started looking at the circuit i got curious as to how much gain it was providing. I didn't figure much if any at all.
That's a simple common source stage, for the basic euquations look in wikipedia:
Common source - Wikipedia, the free encyclopedia
R1/R2 = gain is a bit too simplified as the jfet itself does not matter at all and of course there are high gain (transconductance) and low gain parts 😉
Also, 6k in the source are a little...uncommon. You will be driving any small signal jfet near pinch-off voltage limiting signal swing. Better try smaller source resistor and smaller load resistor.
Have fun, Hannes
EDIT: just thought over your last post: sure, that's ok if you want to add sound to the circuit 😉
Have fun, Hannes
- Single Jfet amp How to calc gain?
