• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Single-ended output transformers 2A3/300B
POT-SE-3,5/8-30 single-ended output transformers for assembling a single-ended tube amplifier on a 300V, 2A3 vacuum tube with sealing in a casing.
Technical specifications:
primary impedance 3. 5 kOhm
secondary impedance 8 ohms
The magnetic core is a batch of plates EI96x45 . *Annealed steel M6 (M165-35S) plate thickness 0.35mm,) manufactured in Germany
Magnetic core cross- sectional area : 14.7 cm
Maximum operating DC voltage : 1000 V
Maximum audio output power : 30W @ 50 Hz
Vacuum impregnation with varnish, a bandage made of non-magnetic materials, ideal geometry, the conclusions of the windings are decorated with COPPER mounting contacts
These transformers are designed to be installed through the chassis (with leads inside the chassis)
Each product has an individual passport indicating the marking of the terminals, technical parameters and installation dimensions.
Development and production of the “GOLDENMIDDLE” (Russia)
The transformers are new, from the manufacturer.
Located in St. Petersburg, Russia
Recommended for audiophiles demanding the best from their DIY tube audio projects.
The cost is 430$ per pair
Accepting offers in Bitcoin
