hi all - still starting out here learning about designing and building speakers and im interested in other designs that use a single driver and enclosure with out any other electronics to affect the sound. ive build the Le Petit and im enjoying the sound very much.. i was reading about the new pearl acoustics that manage to go no-electronics.
curious to hear others who have takes on this challenge; tips or other builds to try out. thanks in advance🙏
no driver is perfect.
If you're willing to live with the flaws, that's up to you... but the quirkiness you might like, might be the nemesis of others.
I never understood the movement of "pure audio" in the "hifi" crowd. I mean, some people are willing to pay thousands for a system that is flawed, just to be part of the "in-crowd" of pure-no-dsp-nor-filters speakers.
It's 2023. There are tools available that make the experience awesome, and they do not take the pleasure away, they enhance it.
Anyway, good luck on your search. Wish you find your audio nirvana.
DSP, FIR filters, passive notches, adjustable delays, room correction (water doing what is possible in the physical world), etc...
I do not use electrical filters or graphic equalizers.
I don't care if the speaker's characteristics are wildly different.
These are air-recordings without filters or graphic equalizers.
I'm not going to rate a speaker off a YT recording.
If you are happy, then that's fine.
I wouldn't.settle for good enough, we have tools to make them sound amazing.
Here are a couple newly-made TLonken ~ slot MLTL with good frequency response for my hearing range and listening space.
https://www.diyaudio.com/community/threads/supravox-8-tlonken-while-city-of-22m-laid-flat.393338/
https://www.diyaudio.com/community/...rkaudio-alpair-5-2-in-evansound-3-75l.393909/
Currently I have one more driver with sufficiently wide and flat response -- 8-inch "drum paper" with whizzer branded Isred/HifiBird/MKHIFI -- that could be used stand-alone without any filter. Out of a nontrivial collection.
im definitely not a purist either but im impressend some of the simple, elegant designs that people come up with for single drivers ( Nandappe👍🏻)
That pretty much describes the majority of the speakers you'll see on this section of the forum, so have a browse over the various threads & I suspect you'll be quite enthusiastic about the number of different designs and the creativity shown. Probably something on the order of 99% are using unfiltered wideband (single) drivers. That's basically what the Fullrange forum was set up for, although it does cater for 2-ways using wideband drivers either as a broadband midbass or as a mid-tweeter as well -we're not fascists here. At least, I hope not! 😱hi all - still starting out here learning about designing and building speakers and im interested in other designs that use a single driver and enclosure with out any other electronics to affect the sound. ive build the Le Petit and im enjoying the sound very much.. i was reading about the new pearl acoustics that manage to go no-electronics.
Pure sound is so nice to listen to. Most important, as I see it, is that it is balanced. Preferably as little distortion as possible.
You can like many speakers at the same time even if they sound different.
I have 10 pairs now... All are good in their own way.
Then you mustn't forget the pleasure of building them yourself.
As discussed elsewhere actually not that great a design.
Pearl’s Sibelus is a ML-Voigt with a custom version of the Alpair 10.x.
There are tons of good single driver, nothing but wire between amp & speakers here.
Size, budget, goals?
dave
Or, every driver is a large set of compromises. Do those compromises suiy you?
dave
ah yes i remember that thread now 😗As discussed elsewhere actually not that great a design.
i agree its a strange box but very impressive what the oversizing and baffles can pull out of a little driver.
if any one has a favorite build that does a smaller bookshelf type enclosure id love to see it. .There are tons of good single driver, nothing but wire between amp & speakers here.
and i guess another logical next step would be some kind of onken.
Thanks.
I am trying to make a nice enclosure without using filters or graphic equalizers.
So, It is very interesting and I am very happy.
A wide one ?
Or sit very close ?
Or maybe a shallow box up against the wall ?
I listen probably under 80db mostly light rock from at least 10' away, so tone controls and a squeak of a loudness button is mandatory for me.
However, a single 3" tang band w3-871s open baffle sounded transparent without any eq, but not when you were more than 3' away (to me).
Or sit very close ?
The only one i know that does not need a filter for me is the Mark Audio CHN110. I did not test them all off course, but of those i tested that is it.
I use it in a big MLTL, but it can also be used in a 25 to 30L bookshelf/standmount speaker, tuned to 40-45Hz (depending on how you do it).
Almost all others need at least a singe notch filter to tame the resonances.
- Full Range
- single drivers with no filters / electronics..
