single cabinet...dual rlp-15's...push pull?
since my new Tumult 15d2 is belly up defective after 3 days, i need to find a use for a 3.5 cu.ft. box.
I'm thinking of adding another 1.5-2.5 cu.ft. to the cabinet and mounting a rl-p 15 at each end...opposite one another.
I would welcome all input and anyone with experience with a design like this.
I'm also wondering if a push-pull design would net more output and would there be any cancellation issues from having a driver on opposite ends.
I'm hoping to keep the same or better distortion characteristics as one Tumult 15" for the same level of output.
The Tumult hit 115 dB without distress so i'm hoping that i can still keep things clean with the twins. It models about 5+ dB higher than a single Tumult at all frequencies >20 Hz
Someone mentioned that there will be a release soon...incorporating this very idea. Thanks
