Hi All,
I have been searching the net endlessly for a set of plans.
I run a mobile disco and I have a set of DAS double 15" Bassbins and sometimes it just becomes a pain to carry these around.
So in saying that I am looking for cabinet plans for a single 18" bassbin that will destroy anything. (Im running a RAM Audio 2.0 Amp which is a dream so im not worried about power). The plans also need to be easy to understand.
Any ideas where I could find plans? General Ideas welcome.
Thanks,
Frankie (South Africa)😛
Thanks,
Try Speakerplans. Horns will be more efficient, but they also benefit greatly from being used in multiples. And they use more plywood than a simple vented box, so could be heavier.
Take a careful look at bandpass designs. Tune one for a peak at the kickdrum frequency; you may not need any output below 80 Hz.
Tapped horns are simpler to build than normal horns, but they tend to be huge. And designing them isn't a cookbook process yet. However, maybe there's a proven design already that suits your needs.
The box will depend on the 18" driver you choose/have. A nice easy enclosure is the B&C one but you will need to modify the port length and enclosure volume using something like WinISD (computer program) for it to work properly with your driver.
B&C SPEAKERS
col.
B&C SPEAKERS
col.
