Simulation stability with different models - Dado's 200W CFA
Hi everyone, and happy newyear :wave:
Sorry if this has been discussed before, could not find anything on it.
I have very much enjoyed dado's 200W CFA thread and downloaded the .asc file from post #1582 assuming it is the newest.
I did not have the IRFP240Ckst/IRFP240Ckst models handy, so instead I used the following models from Ian Hegglun.
*VDMOS with subthreshold (c) Ian Hegglun
.model IRFP240h VDMOS (Rg=17 Vto=4.0 Kp=6 Lambda=3m
+ Rs=40m Ksubthres=0.15 Mtriode=0.35 Rd=0.15
+ Bex=-2.3 Vtotc=-6m Tksubthres1=4m Trs1=3.5m Trd1=5m
+ Cgdmax=1.3n Cgdmin=10p a=0.35 Cgs=1.2n Cjo=1n
+ m=0.4 VJ=0.75 IS=10n N=1.5 Eg=1.1 Rb=10m Trb1=3m
+ Vds=200 Ron=0.15 Qg=45nC mfg=VishIH1907)
.model IRFP9240h VDMOS (pchan Rg=9 Vto=-3.76 Kp=9
+ Rs=64m Ksubthres=0.15 Mtriode=0.2 Rd=0.25 Lambda=4m
+ Bex=-2.3 Vtotc=+6m Tksubthres1=4m Trs1=3.5m Trd1=5m
+ Cgdmax=1.6n Cgdmin=30p a=0.5 Cgs=1.4n Cjo=1n
+ m=0.4 Vj=0.75 N=7 Is=10u Eg=3.15 Rb=50m Trb1=0
+ Vds=-200 Ron=0.5 Qg=44nC mfg=VishIH1907)
I then ran the bode plot as is, without changing anything else. It gave strange results, with a phasemargin of only ~39°.
Went backwards in the thread and found dado's latest zip file with schematic and models. It sims fine with expected results.
Then I changed the schematic from dado's zipfile to use Ian Hegglun's models, and I get the above strange behavior.
My impression was that the models from Hegglun and Cordell are all good, but they clearly behave differently.
Is there a consensus on which models to use for IRFP 240/9240 ?
Jørgen
Hi Damir
Before you start to simulate LG you need to set OPS bias. I your case it's about 94 nA.
Models could differ in Vgs(th).
You are correct.
I assumed they where equal models, with regard to "basic" values, which I consider Vgs to be.
I changed P2 to 3K061 to get 138mA OPS bias, and now it simulates close to Ckst models, with ~80° phasemargin
But maybe there is a lesson to be learned afterall: Wrong biasing can turn into unstability.
For me there is one more lesson to be learned: Double check before posting 😱
Regards and thank you for your time
Jørgen
