Hi folks
After having arrived at a "new" speaker concept :
http://www.diyaudio.com/forums/subwoofers/172553-amt-sub-using-dynamic-woofer.html#post2399769
(roughly down from posting #4)
I'd thought, it would be handy to have a somehow accurate simulation tool to have an easy look at possible variants and optimizations.
I've been advised to possibly give AkAbak a try, after Hornresp and AJHorn did not seem to be a good choice.
Needed is a possibility to simulate a *distributed speakers arrangement* in pipes - and possibly add dipole behavior.
I just download AkAbak:
Akabak
and had a look through a few pages:
http://www.diyaudio.com/forums/multi-way/90362-akabak-simulator.html
Thats the starting point.
Any input appreciated.
Michael
Akabak
Michael
After some reading, AkAbak starts to make sense.
First, a most simple simu of the H-frame with only the front duct being modelled - looks definitely promising with respect to the measurements already taken (red trace):
Measurement:
Akabak simu:
This is the code used:
Not too bad for a first lift off, I'd say
Michael
Measurement:
Akabak simu:
Code:
System 'H-Frame Part1' |Anything behind a line is for humans only
Def_Driver '15PW5'
dD=33cm |Piston
fs=40Hz
Mms=84.6g
Qms=16.8
Qes=0.41
Re=5.5ohm
Le=1mH
ExpoLe=0.618
Def_Const |This sets the units within to all be Meters
{ |Starts
Vrc= 9000.00e-3; |Rear chamber volume (litres)
Lrc= 1.00e-2; |Rear chamber average length (cm)
Sd = 860e-4; |Diaphragm area (sq cm)
Sdd = 1600E-4; |Duct Outlet area (sq cm)
} |Ends
Driver Def='15PW5''15PW5'
Node=1=0=2=3
Enclosure 'Rear chamber'
Node=2
Vb={Vrc}
Lb={Lrc}
Duct 'Du1'
Node=3=33
dD=45cm
Len=40cm
Radiator 'DUCT outlet'
Node=33
SD={Sdd}
Label=2
Michael
I got bored.
Try this setup out for starters.
Just add "all" and labels 1 & 2 when simulating. Don't forget to play with the "mic/listener" distance as well.
Code:
System 'H-Frame Full'
Def_Driver '15PW5'
dD=33cm |Piston
fs=40Hz Mms=84.6g Qms=16.8
Qes=0.41 Re=5.5ohm Le=1mH
Driver Def='15PW5''Driver'
Node=1=0=2=3
Duct 'Rear'
Node=2=22
WD=40cm HD=40cm Len=40cm |End Correction is not needed, as the attached Radiator handles it.
Radiator 'Rear Outlet' Def='Rear'
Node=22
x=0 y=0 z=-40cm HAngle=180° VAngle=0
WEdge=43.6cm HEdge=43.6cm
Label=2
Duct 'Front'
Node=3=33
Radiator 'Front Outlet' Def='Front'
Node=33
x=0 y=0 z=40cm HAngle=0 VAngle=0
Label=1
You should end up with something like this, with the total FR, and both ends separately.
Interesting experiment.
I have a few ideas, but some questions first. Can you post the exact measurements of the test enclosure, external is fine, and wood thickness. Was the driver mounted as shown in the 3d shot? Where was the mic placed?
Have arrived at something close to your script yesterday (except the "edge" diffraction statements I have not looked into yet) - but are still a little bit slow in verifying
Thanks for your input - very much appreciated!
regardig "wood thickness" : don't bother, there is no need to get "precise" results - all this simus are meant to just get the trend
regarding "driver mounting" : yes exactly like shown (I have added cone depth in my simu but it does not make the heck of a difference - as expected)
regarding "mic placement" : measurements (right a mouth) also were done just to catch the trend of different arrangements - so no claim to be "absolutely precise"
I will be back with some plots and specific questions soon...
Nice overlay plot BTW, I have to learn how to do this easily...
Michael
Well,I added conical mainly because it adds some un-symmetry in case of H-frame.
For doing the overlay "right", I'm not clever enough as it seems.
As far as I understood there is a max of thee traces to be overlaid. Works if I drag and drop from one plot into the other, but does not work to immediately simulate into one plot only and - also does not work to get / keep the colors of traces adjusted.
Another problem I've come across - seems if I simu close to mouth - approaching 40cm in above example - SPL level sky rocks to several 100dB. Any idea?
Michael
Michael
Boy this took me time !
I always tried to *add* traces to a given plot window - better to just choose / select the scripted labels and every trace is then put into the upcoming plot at once...
Uff!
Michael
Soho54,
I gave the dual chassis N-frame a try.
this is how it measures (red trace) directly at mouth:
Could you have a look if code is ok so far?
I switched / simplified to „dEdge=1mm“ as I found this in the manual to force Akabak to do diffraction calculation as well.
What I'm not really happy with, is to use a „duct“ for the closed end piece.“Waveguide“ seems not to allow for closing one end with a „0-node“ ??
Any suggestions?
here is the simulation result of above code at 1m mic distance:
Quite some room for improvement I'd say - but - at least the deep null seems to be at the right place - as seems to be the up-shift of the first peak captured - as seems the SPL increase at the bottom end to be captured..
Michael
Any suggestions?
Code:
System 'N2-Frame'
Def_Driver '15PW5'
dD=33cm |Piston
Node=1=0=2=3
Node=1=0=200=300
Duct 'DU-r' Node=200=0
dD=10cm Len=20cm
Waveguide 'Rear1' Node=200=2
dTh=10cm dMo=30cm
Len=40cm Conical
Waveguide 'Rear' Node=2=22
dTh=30cm dMo=45cm
Len=20cm Conical
Node=22
dEdge=1mm
Label=2
Duct 'DU-f' Node=300=0
dD=10cm Len=20cm
Waveguide 'Front1' Node=300=3
dTh=10cm dMo=30cm
Len=40cm Conical
Waveguide 'Front' Node=3=33
dTh=30cm dMo=45cm
Len=20cm Conical
Node=33
dEdge=1mm
Label=1
Michael
Soho54,
Composed the conical end piece out of „waveguide“ and „duct“
Code:
System 'N2-Frame'
|-------------- driver ----------------
Def_Driver '15PW5'
dD=33cm |Piston
Node=1=0=2=3
Node=1=0=200=300
|-------------- end driver ----------------
|-------------- rear firing pipe ----------------
Duct 'DU-r' Node=201=0
dD=1cm Len=1cm
Waveguide 'Rear2' Node=201=200
dTh=1cm dMo=10cm
Len=19cm Conical
dTh=10cm dMo=30cm
Len=40cm Conical
dTh=30cm dMo=45cm
Len=20cm Conical
Node=22
dEdge=1mm
Label=2
|-------------- end rear firing pipe ----------------
|-------------- front firing pipe ----------------
Duct 'DU-f' Node=301=0
dD=1cm Len=1cm
Waveguide 'Front2' Node=301=300
dTh=1cm dMo=10cm
Len=19cm Conical
dTh=10cm dMo=30cm
Len=40cm Conical
dTh=30cm dMo=45cm
Len=20cm Conical
Node=33
dEdge=1mm
Label=1
|-------------- end front firing pipe ----------------
Slightly more elegant this way, though the deep null seems to be less correct
Michael
AkAbak doesn't like the listening point to be inside the model. You will also find that you have to place it a bit back from the Radiator as well do to the end correction it adds.Another problem I've come across - seems if I simu close to mouth - approaching 40cm in above example - SPL level sky rocks to several 100dB. Any idea?
The 'Driver' added is the name of the component. I just didn't feel very creative.Why writing:
Node=1=0=2=3
and not :
Driver Def='15PW5'
Node=1=0=2=3
is there a difference?
You don't have to ground the end of a waveguide really.
This is how I would start off. Note that when you start using Waveguides you have to have more exact placements.
Here is a guesstimate.
Code:
System 'N2-Frame'
Def_Driver '15PW5'
dD=33cm |Piston
Driver Def='15PW5''Driver 1'
Node=1=0=44=3
Driver Def='15PW5''Driver 2'
Node=0=1=4=33
Waveguide 'Rear A' Node=22=33
WTh=5mm HTh=36.4cm WMo=8.4cm HMo=36.4cm
Len=18.2cm
Waveguide 'Rear B' Node=33=44
WTh=8.4cm HTh=36.4cm WMo=26.6cm HMo=36.4cm
Len=39.3cm
Waveguide 'Rear C' Node=44=55
WTh=26.6cm HTh=36.4cm WMo=36.4cm HMo=36.4cm
Len=21.5cm
Radiator 'Rear Outlet' Def='Rear C'
Node=55
WEdge=40cm HEdge=40cm
Label=2
Waveguide 'Front A' Node=2=3
Len=18.2cm
Waveguide 'Front B' Node=3=4
Len=39.3cm
Waveguide 'Front C' Node=4=5
Len=21.5cm
Radiator 'Front Outlet' Def='Front C'
Node=5
Label=1
Thanks soho54
good hint regarding theres no need for closing a WG.
Your code sim's like that:
not that bad - but - what you think could achieve even better correlation to measurements?
I messed around with the idea of distributing the 15" chassis into a hex arrangement to come closer (in simulation !) to the fact that the 15"ers actually do *not* radiate into the wave guide at *exactly* one point only.
This "distributed" radiation into the WG must IMO result in a strong FR difference, as "resonance modes" are excited in a pretty different manner that way.
Simu I got - sadly - are even less "the real thing":
Peaking is way too hot and not a t the right place as well - also deep null (400-500Hz) filled too much
here is the code I used:
Measurement at mouth (red trace)
Michael
Code:
System 'N2-Frame' | N-frame Deep Frame Dipole / outer dimension 40x40x80cm / 2x15" arranged distributed in "hex+centre"
Def_Driver '15PW5'
dD=12.5cm |Piston
Driver Def='15PW5''Driver 1_1' | "distributed" driver "hex+centre" arrangement
Node=0=1=310=201
Driver Def='15PW5''Driver 1_2'
Node=0=1=309=202
Driver Def='15PW5''Driver 1_3'
Node=0=1=309=202
Driver Def='15PW5''Driver 1_4'
Node=0=1=308=203
Driver Def='15PW5''Driver 1_5'
Node=0=1=307=204
Driver Def='15PW5''Driver 1_6'
Node=0=1=307=204
Driver Def='15PW5''Driver 1_7'
Node=0=1=306=205
Driver Def='15PW5''Driver 2_1' | "distributed" driver "hex+centre" arrangement
Node=1=0=206=305
Driver Def='15PW5''Driver 2_2'
Node=1=0=207=304
Driver Def='15PW5''Driver 2_3'
Node=1=0=207=304
Driver Def='15PW5''Driver 2_4'
Node=1=0=208=303
Driver Def='15PW5''Driver 2_5'
Node=1=0=209=302
Driver Def='15PW5''Driver 2_6'
Node=1=0=209=302
Driver Def='15PW5''Driver 2_7'
Node=1=0=210=301
Waveguide 'Front A' Node=211=210
WTh=1mm HTh=40cm WMo=2cm HMo=40cm
Len=4cm Conical
Waveguide 'Front B1' Node=210=209
WTh=2cm HTh=40cm WMo=6cm HMo=40cm
Len=8cm Conical
Waveguide 'Front B2' Node=209=208
WTh=6cm HTh=40cm WMo=10cm HMo=40cm
Len=8cm Conical
Waveguide 'Front B3' Node=208=207
WTh=10cm HTh=40cm WMo=14cm HMo=40cm
Len=8cm Conical
Waveguide 'Front B4' Node=207=206
WTh=14cm HTh=40cm WMo=18cm HMo=40cm
Len=8cm Conical
Waveguide 'Front C' Node=206=205
WTh=18cm HTh=40cm WMo=22cm HMo=40cm
Len=8cm Conical
Waveguide 'Front D1' Node=205=204
WTh=22cm HTh=40cm WMo=26cm HMo=40cm
Len=8cm Conical
Waveguide 'Front D2' Node=204=203
WTh=26cm HTh=40cm WMo=30cm HMo=40cm
Len=8cm Conical
Waveguide 'Front D3' Node=203=202
WTh=30cm HTh=40cm WMo=34cm HMo=40cm
Len=8cm Conical
Waveguide 'Front D4' Node=202=201
WTh=34cm HTh=40cm WMo=38cm HMo=40cm
Len=8cm Conical
Waveguide 'Front E' Node=201=200
WTh=38cm HTh=40cm WMo=40cm HMo=40cm
Len=4cm Conical
Radiator 'Front Outlet' Def='Front E'
Node=200
dEdge=1mm
Label=1
Waveguide 'Rear A' Node=311=310
Len=4cm Conical
Waveguide 'Rear B1' Node=310=309
Len=8cm Conical
Waveguide 'Rear B2' Node=309=308
Len=8cm Conical
Waveguide 'Rear B3' Node=308=307
Len=8cm Conical
Waveguide 'Rear B4' Node=307=306
Len=8cm Conical
Waveguide 'Rear C' Node=306=305
Len=8cm Conical
Waveguide 'Rear D1' Node=305=304
Len=8cm Conical
Waveguide 'Rear D2' Node=304=303
Len=8cm Conical
Waveguide 'Rear D3' Node=303=302
Len=8cm Conical
Waveguide 'Rear D4' Node=302=301
Len=8cm Conical
Waveguide 'Rear E' Node=301=300
Len=4cm Conical
Radiator 'Rear Outlet' Def='Rear E'
Node=300
dEdge=1mm
Label=2
Michael
Ahh - here is the plot (two 15" *not* "distributed") with only the front radiator active to allow for tighter conditions of measurement versus simu:
The upper part of bandwidth (till 300Hz) is not bad - but the the low frequency slope comes in too high - at roughly 90Hz instead of around 40-50Hz
Michael
Michael
Ahh - here is the plot (two 15" *not* "distributed") with the rear radiator having "edge / diffraction" feature disabled:
The low frequency slope is where it should be (no more closed volume
like in my previous post) but upper part (till 300Hz) is not "as expected" - not at all
Michael
Michael
In the pic of my sim, we seem to be looking at the whole system. I would stick with Label 1 to compare to your measurements.
Once you start using waveguides placement is paramount. I just guessed at some simple figures for the enclosure and driver placements, so there is an error factor right there.
The other problem comes from using a waveguide in a sim. The sim only calculates the waveguides contribution, and not the extra direct sound from the woofer. It is the same condition that produces the early roll-off up top in a mid-horn sims, and the "hybrid" horn roll-off down low.
I have a couple of ideas on how to get around it, but I haven't had time to play with it yet.
Yeah we can try...
I have tried to bring the rear radiating SPL contribution out of picture by:
- adding a quasi IB (short but very wide WaveGuide) to the rear outlet
- setting the distance for the rear outlet way back (some -10m)
Both attempts actually did not work, so, I'm a little bit lost to which point AkAbak sims correctly regarding edge / 180deg diffraction - besides all quirks with the "distributed speaker" alignment in the pipe.
Michael
All you have to do is use the Labels section in the SPL simulation setup screen.
If you check a box the graph will only be from the output Label you picked. If you pick Label 1 you will only get the output from the forward opening. If you pick Label 2 you get just the rear. Selecting All or N2-Frame you get the combination of both sides.
Just selecting Label 1 is like getting a near field measurement. This is how you get around the program going a little nuts from having the listening position to close to it, and the SPL shooting way up.
Either way this is still only going to show the waveguides contribution, when in this case you have to combine the waveguides output with the traditional IB output as well.
- Design & Build
- Software Tools
- simulating "Deep Frame Dipoe" (DFD) Woofers, AkAbak?
