Still Vinyl is happening again in Lisbon. (In 2007 I met there Mr. Van Den Hull)
www.stillvinyl.com
http://www.audiomania.com.pt/index.php?topic=3540.0
Look what I found: http://www.youtube.com/watch?v=2T1PRoNshDo&feature=related
Made me look Kuzma from another angle !
Another important link to Rui Borges TT :
http://www.audiomania.com.pt/index.php?topic=2881.0
www.stillvinyl.com
Ricardo
Thank you for the info, Rui Borges is doing a fine job.
Joao
Althea Musica
PS.
De onde vc mora em Portugal?
Um bom fim de semana.
Joao
Althea Musica
PS.
Hi João
I really apreciate Rui´s work so I am looking forward to see him at the event.
I live in Cascais
Ricardo
I live in Cascais
Ricardo
Caro Ricardo
thanks for the info. I hope I can attend to the event / show in the future as well and present my Vega turntable as well.
Joao
Joao
Hi João
Hope you can join us... this year CD is interdited in the show... It will be much more powerfull than what happened in 2007.
Rui has built a new very heavy TT and is presenting it... I reallty like his work... All RB TT have the enourmous soundstage with incredible silences and superlative dinamics 🙂
It is incredible as this show was organized by a group of "Audiomanyacs" used to share ideas on a local forum.
I am very happy to see such a demonstration of care to vinyl.
I will be there browsing the ususal collection of rare special discs.
Can you post some pics of your vega TT ?
Ricardo
Ricardo
Now back to basics..... using special cable between the TT and the riaa is really very important.
The riaa is so transparent that can expose and amplify the better signal comming from the cart.
I replaced the stock arm cable on the rega P3 and now I understand all the rave about the "budget" DL160.
This cart is capable of really big soundstages with very good detail in the bass and sweet informative trebble when used with the correct equipment:
geddonized Rega P3
"Special Reserve" arm cable
Salas double mono Riaa with upgraded V1 shunts
"Special Reserve" cables from riaa to pre
Ricardo
geddonized Rega P3
Ricardo
Hi Salas
A good friend of mine dropped me some 220nF FT-3... These are exactly the same diameter and construction as the 100nF but about 25% longer.
Can I use these as interstage couplers in the riaa ?
Ricardo
Ricardo
Avoid. With 100nf it goes really low, you will just add double the capacitor film there for no reason.
Caro Ricardo
I will not enter this thread. Please send me an e-Mail and I am sending you some HRes images and more info.
Joao
www.altheamusica.com
info@altheamusica.com
PS:
I'll provide this as well for all interested forum members
Joao
PS:
Hi All,
Had not posted here for quite a while...I did an AB of my Salas RIAA (with generic parts) against a Trichord Dino phonostage and matches it sonically imho. Hope to build another one with the recommended components soon.
Tham
Tham
Pretty good for generic. You even have electrolytic capacitors in series with the signal if I recall correctly?
Hi Salas,
I have 2 spare 2.2uF MKT1822 which I would like to try at the output. Would the smaller cap be a problem?
2u2 are good for no less than 40-50k line input impedance, when preserving the intended subsonic behavior. If your line stage is there or above, fit them. Any MKP at hand?
Hi Salas,
I will put them in and report my result when they run in a bit later. Have 2 2.2uF MKP audiophile caps (China made) and will try them too. Many thanks 🙂.
You are welcome. I guess that your line stage has the adequate input impedance I mentioned then.
LDR is from 7-10k if with George's circuit, so you will need 10uF I am afraid. At least bypass the Elna with those you got.
- Analogue Source
- Simplistic NJFET RIAA
