Simplistic NJFET RIAA
That means there is 6.12mA running in the resistive Vref and normally you could set between 21 to 43.5V. If the trimmer is indeed changing Ohmic value when you turn, then I would be very suspicious of Q2 and Q3 first when having VGS on Q4. Does Q3 show healthy Vbe?
2.2V is little. The sense circuit must be tied to the force circuit terminated with a load consuming much less than the CCS circuit provides. It should show Vout at its tips too. Is it configured like that now you measure?
Tomorrow, it begins. Here are the boards and prereg.
