Simplistic mosFET HV Shunt Regs
I connected directly the PSU to the load max Vout 75V but something is wrong or incorrectly wired because I used and old SSHV2 with the pads broken, please could you check the attached pic if all connections are OK?
I think of no reason than some practical error not to work when having a limiting resistor.
Also:
"Another test tip is, as the circuit is off power, Q5 between E,B pins on Ohm meter with red probe on E should be reading in the hundreds of Ohm and changing reading when turning the R11 trimmer. When a blown Q5 could read a couple of Ohm near short. Q4 should be reading in the hundreds of kilo Ohm on same test probing (the trimmer is not involved in Q4)."
