Simple SE with KT88's
tubelab.com said:
There is a fuse inside the IEC. I use these too it saves one hole in the chassis.
LOL, that's why I never do anything serious after a long work day :clown:
A question for you, George. Is 2.5K primary too low for the SSE? Or, it is better to save them for Tubelab SE later? These are Hammond 1627SEA.
Thanks!!
I think my OPT's might be arriveing today. So...
I need to know something.. Cathode feedback or NO Cathode Feedback?
I'll be setting up the amp intialy on a bread board wired for triode only with a choke and a motor run cap.
After everything looks to be running good I will be adding a UL switch and have the amp wired for Triode/UL operation.
So I need to know weather or not I should use Cathode feedback or not. I don't know what the difference is between the two.
Nick
Start with no cathode feedback. It makes the wiring just a tiny bit easier.
I usually start with no feedback triode mode. The wiring for UL is similar so triode is just my preference since some OPT's don't do UL, I always start from the same configuration.
I could never get a 3 K OPT to sound as good as a 5K OPT with 400+ volts of B+. I have been using my 3K Transcendars with the 8 ohm load on the 4 ohm tap to give the tube a 6K load in the Simple SE with the Allied 6K7VG transformer. A 2.5 K load would work with a big tube (KT88) and a lower B+ like about 340 to 360 volts.
Alright folks.. I'm ready to fire up my amp and I am as nervous as I could be..
What should I do?
Should I leave the tubes out and check the board with mulitmeters?
If so. Where should I probe and what numbers should
I be looking for?
Also I'll need to know what connections are AC or DC..
And how to connect them. Is there a common ground on the chassis that I can connect the gound on the volt meter to?
I have alligator clips to use so I don't have to go probing around the amp unless I have too.
Or should I just stick the tubes in fire it up and see if it works...
Nick
Nick,
Please follow George's tips on:
Checkout
http://www.tubelab.com/AssemblyManualSimpleSE/Checkout_SSE.htm
and safe meter usage
http://www.tubelab.com/AssemblyManualSimpleSE/MeterUse_SSE.htm
Everything before the rectifier is AC, everything after the rectifier is DC.
Also, do not use your good speakers to test the amp for the first time - just in case. Either use a dummy load, or a junky pair of speakers.
Thanks but not exactly what I am looking for...
So anywhoo..
I turned the amplifier on without tubes. I can't get a reading on anything anywhere except the T1-Red. T1- Yellow reads nothing. The B+ going to the OPTs reads nothing. C1 reads nothing...
I am getting nothing on the board except T1-red which reads 425volts with no tubes.
Put the tubes in the and 12at7 and 5ar4 start to light up and then the fuse blows.
So this is where I am as of right now.🙁
Nick
Sure, without the rectifier tube, there will be no B+, so you will only read the AC on the secondary of the transformer.
When the rectifier starts to warm up and conduct, the B+ will slowly rise and then the fuse will blow - I suspect you have a solder short or a misplaced wire somewhere.
Take your ohm-meter and, WITH THE POWER OFF AND the MOTOR RUN CAP DISCHARGED, measure between B+ and ground, make sure you do not have a short.
Another quick check is to make sure you installed the 10M45 ICs correctly.
Can you explain to me how to do this as if you were telling a 5 year old?
I have a Fluke 29 but I be damned if I know how to work it...
I feel like I might have taken on too much.:bawling:
Nick
Heres a couple pics.
[/IMG]
[/IMG]
[/IMG]
