Simple SE with CCS and fixed bias
Having built 2 PP amps, I am now searching for my next project, and I would like to try an SE amp. I have spent a fair bit of time reading about tubelab's SE and simple SE designs.
I am intrigued with the 10m45, mosfet coupling, and fixed bias of the Tubelab SE, but I am nervous about smoking my precious few DHT ouput tubes ( a couple of 2a3's and 45's) that are in my stash for future use as I am still a semi-newbie.
I have a pair of 350-0-350 100ma transformers, a few EL34's, 6l6GC's, KT88's, 6550's, etc and a small assortment of small signal tubes including 12AT7's and 5842's. I have not bought any output iron yet.
I am planning on monoblocks with point to point wiring.
So here are my questions:
Would it be a relatively simple matter to construct the simple SE with fixed bias? The reason I ask is twofold, I seem to prefer the fixed bias approach and I believe my transformers are a little shy on B+ for the simple SE.
Conversely, can the output tubes above work in the tubelab SE with minor mods? That way I could tinker with the CCS, B+, and bias adj without fear of smoking my DHT's.
Are there any other schematics that someone can point me to that use the common output tubes above in SE, fixed bias, with a CCS?
