Simple passive preamp. Neen some help in grounding.
Gordy said:
Nobody said tie them directly. Experience suggests that they should be linked such that there is a dc path, with a low value resistor or small inductance being suitable for the link.
You are correct, nobody used the word directly. BUT, somebody used the words
joining only at the mains (or in this case, at the chassis).
with no mention of a resistive component. I would think specificity would be important in this case.
I'm not trying to be argumentative, just trying to get to the bottom of it...
But that's not what he said or was implied
I cannot see how this conclusion was reached.
I'm reacting to Andrew's non-response through reiterating his original comment inferring some higher authority.
I never implied any high(er) authority.
I see no point in trying to ram my opinion down your throats. It's only liable to choke one.
Similarly, there is little advantage in simply repeating what "I would do".
Tell us the alternatives and how these alternatives solve the loop problem, if one exists.
Then the enquirer can decide for himself/herself.
I decided to go this way (see attach). Both grounds (L and R) come together only on chassis thru low ohmite resistors. No obvious loops at all. Ground shield on PCB is attached to "chassis" point.
One last comment. I follow every thread that discusses grounding. In most any discussion Andrew weighs in and quotes from the "higher authority I alluded to" Passing on useful information to those who ask. I have no issue with alot of it. I don't know the distinction between ramming and being an outspoken source.
My point of view is different and it would be interesting if I pointed out a difference and someone tried it and got back with feedback either way. Hasn't happened yet, didn't happen this time.
Whatever. Mike.
I also see no reason to join signal ground to the chassis or PSUs ground in any way whatsoever.
IMO ideally you'd keep signal ground separate from PSU ground, I see no reason why you couldn't keep left/right grounds separate (but I wouldn't bother), but I can see some potential merit in not having all the input sources grounds constantly connected - this seems to be the "dodgiest" aspect of this design to me, but I can definately see why it'd make it more complicated.
