Simple passive 3D, single panel!
Ok... the quest has been long... but tonight I finally managed to get a passive 3D projected image.
I used an LG Cinema 3D LCD panel and was having trouble getting it to project in 3D... I could see that the image had both left and right... but it wouldn't view correctly with the glasses.
Tonight I tried some fault finding... putting the backlight back in in case somehow that was where the polarizing was coming into play... and at first look it was working... so I put it back into my projector and I was back to square one... but then I noticed the other side of the panel... and decided to look at that with the glasses on and low and behold it worked... so, I took the panel and turned it around... Voila! 3D projected image.. now granted it is currently flipped back to front, though if memory serves people have been known to use mirrors in their projectors to primarily make smaller boxes but I may be able to use the same trick in order to right the image and the mirror should keep the same polarity anyway.
The biggest laugh of the whole experience, it turns out my feature wall which is purple (and where I hang my commercial projector screen)... must have some degree of aluminium flaking or something in it because it actually reflects the polarized image correctly to allow 3D viewing!
So people can stop worrying about having to get two projectors or two panels etc... grab a nice (these days pretty cheap) passive 3D monitor and stick it in your projector, no need to worry about image splitters or anything like that, I ran mine straight through my PS3 and played the Star Wars Pinball demo... yes that's right my first projected image was of ATAT walkers in 3D!!!
the LCD panel I think was about 23 maybe 25inches... so not ideal and was cutting off the edges... but not so much that it hampered viewing enjoyment... me accidentally shorting the power board however... that has hampered my viewing full stop.
HI blennu
I am impressed that you succeeded for 3D but the problem is 23inch is quite big.... can we use the 10.1 inch or small mobile LCD/Tab LCD for this type of project...
For 23 inch the box size will huge.
Regards,
Biswanath
India
:magnify::magnify::magnify:
