Simple non-digital input selector
Use signal relays that work well at low current.
If you don't want to build one, here's one that I have used.
Looks like DSP relays...might be low current but not what I would call signal relays.
Relays to use:
IM relays (IM07 is 24V coil) are min 100uV
(mickeymoose)
G6A-274P-ST are min 10uA / 10mV min signal
G6K or G6S series are also min 10uA / 10mV min signal
Signal relays or Telecom relays are what to look for.
Look for low switching voltage in the data sheet.
Relays to use:
(mickeymoose)
Then again, what do I know? :)
