Simple MOSFET preamp
Another simple preamp if someone has some time to kill. IT has a very nice, sweet tone.
The output is 4uf but can be changed depending on the input Z or the poweramp. They run at less than a watt and after an hour aren't hot. Power supply voltage can be higher but disspation will increase.
I suspect fairly high second order distortion which gives it a nice tone.
...what is the minimum voltage?
I would suggest not attempting to run the circuit on a much lower supply voltage. The reason is, that a lower supply voltage risks significant modulation of the input capacitance of the MOSFETs. Resulting in significantly increased distortion. A quick look at the DN2540N5-G datasheet indicates that the 60V supply voltage chosen by scholl seems a good figure.
