Simple MM only RIAA preamp
Hi all,
here is the link to the article (unfortunately, in Russian) I've published in 1999 in "RadioHobby" in Kiev about the original idea behing Creek Audio OBH-8 preamplifier. Since that time newer versions of this circuit are used in the current line of OBH preamps. However, this circuit is a good example of what could be done with few transistors. The sound of this circuit is good and it is very DIY friendly 🙂 .
http://vlab.netsys.ru/audio/lpcor7.stm
It is single-ended class A with passive EQ. What else would you wish? 🙂
Technical Data of this preamp:
Gain - 90
SNR - better than 70 dB A-wtd ref 5 mV 1kHz input
RIAA deviation +/- 0.5 dB 50Hz-30kHz, -3 dB at 20 Hz
Max. output 5V RMS
Distortion for 1V output - less than 0.01% at 1 kHz
To prevent possible questions - it is my own design and the original publication was made with permission from Creek. The circuit is copyright of Creek Audio Limited (it is printed in the original article, unfortunately on the linked web site they cut the picture and lost it... .
Enjoy
Al
2 Werner - yes, Pacific is simpler, however it does not have much gain and it's linearity is somewhat suspect 🙂 . My circuit does have high enough gain and reasonably low distortion - even at 4-5 V RMS output, just before clipping, distortion are about 0.1-0.2% at 1 kHz. And this is using only one gain transistor Q1 - the rest are followers and a current source 🙂.
2 hsort - it is 90, or about 39 dB at 1 kHz.
Al
Koinichiwa,
Linearity is arguable, though the harmonic structure of the Pacific is exemplary.
The gain is actually higher than 90, assuming the correct FET's are used. The 2SK170 @ 5mA has around 30mS (30mA/V) transconductance and operates into around 2k4 Loads. This gives a stage gain of 30mA*2.4k = 72. With 2 stages the overall gain becomes 5200 or 74db, of which a bit over 20db are lost in the passive RIAA EQ.
So the Pacific after accounting for the RIAA has around 60db Gain and around 0.15uV Ein (150nV Input Referred Noise) which makes it (marginally) suitable for medium output MC's without further Stepup or Pre-Pre. Output Impedance is around 2k. Not bad for a brutally simple circuit.
A friends Pacific runs fine and sounds VERY good. Originally it used 9V Block Batteries, when it stayed with me for a while (it drove a S&B TX-102 ever so much better than my Shindo copy Preamp) I converted it to using a 24V non looped switching supply, with better sound than we got from the batteries and no regular recharging!!!!
[/B]
Mebbe, but what does the harmonic structure of that circuit look like and what does it sound like? The original Creek phonostages sounded uninspiring.
Sayonara
Konichiwa Thorsten-san,
I just finished building an "el Cheapo" for a friend (thank you for the advice). Even though I had to build it on a budget and skimp on a few components, it sounds fanastic, shockingly so.
I am in the middle of building a new turntable for myself. I want to build an intergrated pre, hardwired to the arm and interconnect. I chose the Pacific, because of it's simplicity it will allow me to keep the footprint small enough to fit into my arm base, plus I already have a boatload of the correct fets. I was wondering if you had any suggestions for the components to use(brands, models) in it's construction, cost is not much of an issue, but availability is, I hate hunting for parts and ordering from more than one or two sources.
Domo aregato,
Bart G.
Re: Konichiwa Thorsten-san,
Koinichiwa,
We build the whole circuit hard wired, in a copprfoil clad wooden enclosure. We used Holco Resistors (sorry, no longer available as non-magnetic, current Holco's are NDFG), LCR 0.47uF Foil & Film Coupling Capacitors (plus MIT 2u2 PPMF "bypass" on the output) and LCR Polystyrene Cap's for the EQ. This Parts Mixture is true "UK Style" and most components are/where available from Radio Spares and/or Farnell.
Sayonara
BTW...
Have anyone tried this? comments?
I think it is from a Hafler Pre-Amp....
Arne K
Pacific
Hi all,
just finished my version of the pacific (some pics are here I guess you will need an yahoo-account, for i have no own webspace)
It has an additional MC-Pre Stage. Thorsten is right, it has lots of gain (acutally a bit too much)
As a friend stated, it sounds that 'you miss nothing'.
(Same night we tried the blue amp phonostage, well, there is still a lot to improve...)
It is a good value for money, but, on the other hand, no 'beats everything, costs nothing'. Of course, other implementations may sound different.
Rudiger
Re: Pacific
Koinichiwa,
Nice work in general, but the ouput coupling cap is a little prosaic.
You can reduce the Drain Load resistors of all stages to reduce gain. This will also allow you to "tune" the sound somewhat. Just as with Pentodes, the J-Fet is more linear into lower loads.
However, the biggie (if you ask me) is to add a third battery and to cascode the two J-Fets with a nice bipolar transistor each, base connection directly to 12V, +V 36V. This makes the drain load of the J-Fet almost zero, maximising the linearity of the circuit.
You may be able then to increase the Gain further by adding the +V up to 48V and doubling or even trippling the load resistor, which may allow you to remove the MC Pre-Pre stage.
Sayonara
... , but the ouput coupling cap is a little prosaic.
Quiet true
:goodbad:
At least the drainres of the stage before the riaa is part of the network, if I understood it right, so tuning might outtune things...
That may be worth a try.
thanks,
Rudiger
Pacific RIAA - final touches/questions
Hi all,
Some months ago I have built a copy of Pacific and I really like it. The gain is more than enough for my high output VDH MC2.
I used parts from my stock ( beyschlag mf 0.6w resistors, ICL MKP capacitors, SCR tin foil 100n, 2 SLA 1.2Ah // a Mallory 12000uF ) , and I must tell you that this little thing really sings..
Later I added a 470uF decoupling capacitor + 10R carbon film isolation resistors per fet , 100R carbon film "gate stoppers" and finally stacked a 110R resistor on the 30n RIAA capacitor (hidden tc).
All of these changes improved the sound especially the decoupling capacitors.
Now I'm finishing a second build using better parts ( Maplin M mf resistors, SCR tin foin caps, silver mica 30n, Elna Starget 470uF )and better layout but I have two questions.
- The prototype plays ok with the 100K input resistor but the recommended loading for my cartirdge is 47K. Should I change it to 47K or I'm altering anything important for the operation of the 1st stage ?
- The correct position of the resistor for the hidden tc is on top or at the bottom of the 30n cap ?
Any other suggestion/advice is welcomed.
I'm learning but slowly......
Thanks in advance for your help
Marinos
never heard about adding a resistor for time constant.
But another thing: I recently wrote, the pacific didn't reach the awaited sonic level. Meanwhile I replaced the accus with big panasonics (7,2Ah each) -- it is a completly different thing now.
Sound is deep, tight and sweet at the same time. Not bad, really!
Rudiger
Hi Rudiger,
Adding a resistor to the HF part of the filter you stop boosting the HFs at around 50KHz (3.18 ìS). This has been referred as the 4th or hidden time constant. See this link for more information.
http://www.klaus-boening.de/html/timeconstant.html#time constant
Experienced guys, like Werner in this forum, have mentioned the difficulty of making a suitable PSU for pacific. I started with batteries and from the beginning I have really good sound from it.
Using 7,2Ah SLAs you start with a clean supply, with an internal resistance around 20 mOhm, and capable of huge transients.
I think that this is what you hear now.... Do you bypass the batteries with a BIIIG capacitor ?
Sorry but what do you mean with 'accus' ?
Marinos
Pacific Yes..
Hi Jocko,
I also think that something is wrong with RIAA values. With 27K, 3K, 100n and 30n the sound is bass heavy and a little splashed highs. I checked the values with TCJ's RIAA calculator and I came to the following better sounding values 24K9, 3k2, 100n, 35n.
These values are very close to Werner's Pacific variation (see attachment). What values did you use?
For the Pacific "as is" I will only check if moving the 470n coupling capacitor after RIAA sounds better.
For a "modified" Pacific I would like to implement Thorsten's suggestion (see this post, BJT cascode....). Sorry but I don't have the background... to understand the " ...a follower in between..". Could you please explain this in more detail ?
Any better RIAA pre suggestions ?
Marinos
Hi Marinos,
with accus I meant batteries, and yes, these are bypassed by huge amounts of uF...
from my limited experience I might add the following:
1) If you use 1.8K Drain-Resistors instead of the mentioned 2.4 K, you change the riaa network as well! Lowering the 27K might cure this. You will as well get lower gain with 1.8
2) I really made a big effort to decouple the very first stage (head for MC-pickup) (choke, Res, couple of caps). That paid!
3) what's the point of the 2.2megs?
Suggestions for better? Currently, I'm building la bohème, we'll see...
Thorsten's suggestions seem to be inspired of klaus boening's design, I think...
Rüdiger
Konnichiwa,
I think not.
We added cascoding Transistors to the Pacific long before Mr. Boening published his design.... I have liked using Cascodes in Solid State Circuits for a long time as they allow to combine devices to achieve normally conflicting performance items.
The simplest way to add the cascoding is to use good (Low Noise High Ft, High Beta, good Beta Linearity) NPN Transistors like BC239 and use a stack of 3pcs 12V Batteries for the Supply. The BJT's are added between FET Drain and Drain resistor with the Emitter to the Drain and the Collector to the Drain resistor.
Simply connect the Base of the Transistor(s) to the top of the first Battery (+12V) and apply +36V (nominal - in reality over 40V) to the +B Line. Worked a treat for us. BTW, the Drain Resistor should drop around 12V and the 2SK170 MUST be selected for identical currents for the two channels plus should have Idss of 4 - 6mA....
If one wants to implement Jocko's suggestion to place buffers simply add another BC239 Transistor with another BC239 as CCS. The Base of the first BJT goes to the signal takeoff Point, Collector to +B and the signal is taken of the Emitter. The RIAA needs re-calculating then.
I have done this and attached what I would suggest in this case.... Not as simple as before, but still a minimal number of components per gainstage (6components) and all the transistors can be glued together and hardwired so that hardwiring the circuit in air is still a perfect possibility. And each such gainblock offers a very low noise level with a gain of around 36db and pretty decent (thanks to cascode) linearity.
Another Idea, the schematic as posted here would be usable with the S&B 600R RIAA Module.
Simply connect a 600R resistor between the output of the first stage and the RIAA Module Input and remove all the other RIAA components. As the RIAA is input terminated the RC combo coupling to the next stage can remain just as shown....
Sayonara
