Hello,
Is there any simple hybrid amplifier schematic/projects that recommended for construction?
Like the hybrid amplifiers from CROFT:
Simple Hybrid
Here you go...
http://www.diyaudio.com/forums/tubes-valves/226405-simple-hybrid-amplifier-35w-8ohm.html
Here you go...
Good request foxye, i'm also interested in hybrids especially now that i have plenty of bjt's from ON Semi to use as well as power Mosfets to use as output buffer and looking for stable one.
also, maybe someone kind enough to share some schematics with Triode-Pentode tube as inputs. Like 6f5p or 6bm8, triode section as voltage amplifier and the pentode section as cathode follower...any schematics please?
last blog from Tubecad goes into hybids. I think that something like the first schematic, with OPT instead of the 2k5 resistor could work out quite nicely.
Supercharged Output Stages
but there are zillions of way to make simple hybrid amplifiers.
Joined 2009
I recently presented the C-Vac concept. It isn't a hybrid in itself, but it allows you to build hybrid amplifiers from a pure tube source schematic.
For example you could translate a tube direct-coupled headphone amplifier into a speaker capable amp, and that is true of any tube topology.
An application is shown here, the SolidGlass amplifier:
http://www.diyaudio.com/forums/tubes-valves/235390-application-c-vac-solidglass-amplifier.html
- Tubes / Valves
- Simple hybrid amplifier
