Simple FM transmitter problem
1: Use an RF transistor...2N5179 or equivalent (the 3904 has an ft of 300MHz, so a gain of 3 at 100MHz)
2: Use higher resistance divider for bias for Q3 (what you have is probably saturated) a couple of 100K would do better.
3: Use small coupling cap for antenna to minimize load pulling.
I built one as a baby monitor many years ago and used a logarithmic compressor on the audio so we could hear breathing but would not be blown out of the room when a plane flew overhead. It showed very little drift.
Ragarding 2, I am aware of the close to saturation bias point, it is 8.63V at the base with a 9.09V supply. I was planning to change that too but it did not appear to be a major issue since it works but only with small audio inputs (that don't exceed around 0.3 Vrms).
I will try a coupling cap for the antenna too. As far the transistor is concerned, I will see if I can get it here. 🙂
