Silvertone 1485 - Output Transformer advice
Hello all,
I recently picked up 2 extremely beat up silvertone 1485 heads cheap from a guy who had done some ...interesting... mods. To refresh your memories, these are 4x6l6 amps that used two (wimpy) O.T.s, each running three 10" speakers (a 2.6 ohm load for each transformer) in a massive 6x10 cab.
Schematic (PDF)
Apparently, he had killed one or both of the OTs in both amps, and used some interesting methods to "fix" them.
In the first head, he took out both OTs and used a single (massive) OT from an old RCA theater amp. After a couple of replaced tubes, that seems to work fine, and the wiring pretty much makes sense to me.
The second head is more of a head scratcher, though. One of the OTs is fried, and he apparently hooked it up so that the remaining OT is running all of the output. This does not seem right to me, but I'm trying to figure out the best way to proceed... My goal is to be able to use the amp with one of my existing cabs (all 8 ohm, various configurations) if possible.
Option A: replace the dual OTs with a single, higher powered one - maybe a Fender twin OT? This is pretty much what he did with the first one, and I think it would work fine - except I'd have to make a new cabinet for the head, because I can't think of a high-enough powered transformer that would fit in the space vacated by the two smaller ones. If anybody has any ideas on one that might fit, please let me know!
Option B: Replace the one busted OT (or just do both) with the Silvertone-specific replacements from Weber or Mojo. These would fit the chassis, and have a better option in that they're tapped for 4/8 ohm, but I'd still be stuck with the issue of putting together a new cab (or at least of rewiring an existing one to handle the separate/dual 4 or 8 ohm loads). I was wondering if there could be a reasonable way to tie the dual OTs together to run into one cabinet? AND, if so, how would that change the output impedence (i.e., if I could tie the two OT's together at the 8 ohm tap, would that make it need a single 4 ohm load)?
Thanks for the knowledge!
