I have read a few forums stating that silver mica made a big difference to clock performance!
They have low inductance and losses, are stable and accurate, and are good for high frequencies.
I seem to recall reading somewhere that silver mica caps can sometimes suffer from small random step changes in capacitance, which can be noticeable (but only just!) when used in an LC VFO. The effect would be much smaller in a crystal oscillator so perhaps no problem for audio. I don't know.
Thanks for all the input!
Rayma that's exactly what I read about silver mica. So it made sense since it has excellent frequency abilities it some how has a better effect on the crystal and made it sound better. Someone actually posted that it was as good as a clock mod by up to 50-60% the quality! And a lot cheaper and simpler
I am not confident in doing clock mods but caps yes I can do. Now the question is some caps used are not bipolar for clocks but I guess can be bypassed with silver mica?!?
I have a Teac Pd-h500i (currently not working) that uses electrolytic capacitors that I thought about bypassing but is the value of the cap important.
I don't know anything about clocks or the required caps or even type of cap. I just trying to get some professional advice / tried and tested opinion of the best caps to use.
thanks
thanks
Siver Mica is OK
PEN is a dielectric : WIMA SMD-PEN Capacitors with Polyethylene-Naphthalate Dielectric which has few capacitance changes at highs frequencies VS some others dielectric as ceramic class I like X7R for instance: its capacitance curve stays flat at higher frequencies than many dielectric but Silver Mica and C0G/NP0. (jcx member's inputt at the post above)
Conclusion of this thread is you can both use for HF signal path Silver Mica cap or Ceramic class I cap (a.k.a: C0G/NP0).
Silver Mica is maybe more consistant (aging) in time & less fragile, but I'm even not sure of that ! I Just readed the datasheets.
regards
regards
Basically most crystals have 2 caps connected to it. Not Power caps. For example look at pics of my broken Teac cd player 500i. it has electrolytic caps. front is 47 middle 0.1 and back 47 how could this I use silver mica? Can only polarised caps be used?
- Digital Line Level
- Silver Mica for Crystal?
