Signal routing to power amp LM1876 based on TS5A22364
Has anyone ever used the TI's TS5A22364 CI to route audio? I though of implementing the circuit below on which I intend to use the same supply voltage to switch between normally closed and normally closed pins, from a ceramic cartridge preamp and a RIAA one, to a LM1876 power amp. Will it work? Any dos and don'ts abut my circuit?
