Siemens capacitor marking
Hello! Tell me, please, what do the letters "J/S" in the labeling of this capacitor mean?
They are just now celebrating their 49th birthday. The passive parts division
of Siemens later became EPCOS which is now part of TDK. DIN 41197 is the
German standard they have been designed to. That has been retracted and
cannot be bought anymore.
I would not try to open them; they may contain some oil that is considered
cancer-generating nowadays.
regards, Gerhard
OMG. The brand is Siemens and MP stands for Metallpapier / metal-paper.
J/S could stand for the factory where it was made, for a customer, whatever,
but nothing interesting.
It is a starter cap for a cheap 100W async motor, don't treat it as if it was
something special that needed relics worshipping.
However, if we talk about a perfect power supply, using a vacuum full-wave rectifier, which capacitors can you recommend for use (without touching upon the question of the advisability of using a tube)?
If not "motor" siemens MP, then what?
Europe is not 110V land. We had here 220/380Veff, in some countries more.
Add some overvoltage, multiply by 1.414 and see what you get. And a motor
start cap is in series to an inductor. That may yield some extra voltage.
If the cap fails, that results in a disaster; direct short over the mains and the
motor dies, too. That's the reason why they developed self-healing metal
paper capacitors in the first place. The spark vaporizes the metal around
the punch-through hole.
And 2 uF is quite shabby for a plate supply. Even cheap tube radios had
50+50 or 100+100u. There used to be a choke between the two halves,
sometimes the choke doubled as magnet winding of the speaker, before
they had AlNiCo.
