Shunt regulator +-15V
This is quite simple shunt regulator with very low output impedance.
I designed two types of PCB, single shunt regulator and double shunt regulator (in case you what supply for two channels) Output current could be set up to 100 mA.
Damir
I spotted a typing error in the double barrel (winding??) schematic.
I think the "AC 12V" should be "AC 15V"
Okay, enough with the grammarnaziness.
Can the output voltage be adjusted easily by changing some components ???
I will order some boards for single shunt regulator. Minimum order is 5 pieces, I need 2 for me, so there is going to be 3 left. I don't have intention to order double shunt regulator boards as I don't need them, but if there is interest minimum order is 5 pieces.
By the way, the same shunt regulator is used in GanWire mk2 preamplifier.
