Hello!
I am using the 300B JJ and 300BC Shuguang.
One quartett of 300BC with one year of work at 410 Vdc and 50 mA of current ( fixed bias) got three three spot problems ( intermittent high anode current on different tubes).
With same circuit the JJ seems to be run good.
The sound of 300BC is very interesting, maybe better than JJ.
Someone found problems with 300BC?
Thanks and ciao
Walter
Thanks and ciao
Walter
Buona sera.Hello!
Thanks and ciao
Walter
I use Shuguang 300B tubes in my SET amp and they sound good when B+ is at around 370V and bias is at 70mA.
There have been some output tube reviews but they should be taken with a grain of salt. 300B listening tests You don't have to change this output tube to sound different. Just by changing B+ voltage and bias current can alter it so I'm not sure if tube rolling is worth it as long as it holds up.
Ciao.
Hello!
Thanks and ciao
Walter
Walter,
When are you going to pay my invoice number 10350 ? This is from september last year and you are not all responding to my E-mails
Guido
