Showing Filament Connections for Tubes in KiCad
I've just downloaded the latest Kicad and started messing around in the schematic editor. I've noticed that when you place tube symbols, the filament connections aren't shown, even when you place both halves of a given tube. Is there any way to fix this so it shows up in the schematic?
It could be because it's almost universal that filament connections are implied, not shown. My understanding is that this is to keep the schematic clean, and because the connections are AC direct from the transformer. They are shown in truncated form in the PS heater string, often with the symbol for the tube filament.
I'll take a closer look at the Kicad library and see if I can find some VT schematic symbols with filament pins. It'll be important, as I intend to run the two (maybe three, if I include a line stage) tubes in the design with filaments in series from a 12V switching adapter with some extra filtering. Some of he rest of the 12V will power a self-designed DC-DC converter to generate the B+. That bit will live in a die cast box with feedthrough caps so it doesn't pollute the neighborhood. What worries me is when I actually go to net out the design. I've used generic schematic symbols for the resistors and caps, and it may ask for footprints.
If I was free-handing the PCB in Orcad Layout, it would be no big deal, as I already have extensive footprint libraries of the parts I like to use.
The filaments are nested at the bottom level of this drop dpwn
Problem solved - all I had to do was select a dual triode tube symbol, click three times and get all three pieces, including the bit with the filaments. I'm working with the ECC88, as it appears to have the same pinout as the 6JK8 I really have in mind for the project. That's for the RIAA section. For the line amp, I may end up using a 5965, as it has the 12V filament option, and I have a few hanging around.
The stunt I have in mind is described here:
https://www.diyaudio.com/community/threads/folded-cascode-riaa-tube-preamp.396784/#post-7293118
The line amp would use feedback cells similar to those described here:
https://www.diyaudio.com/community/threads/hybrid-riaa-line-amp.339676/page-3
The schematic showing the gain cells is in post 51.
Reactions: kevinkr
I am using the symbols for the ECC88 in my current schematic, as that has the same pinout as the 6JK8. Unfortunately, it looks like the bit with the filament pins is missing the pin 9 shield. I will see if I can edit the symbol to reflect the actual truth of the matter.
Reactions: kevinkr
