Show us the most beautiful speakers you've ever seen... I'll start
I have no collection of pretty speakers as my experience says the prettier the cabinet, the higher the price and the worse the sound.
Take butt-ugly speakers like the 2Ce. "Not in my living room" I was informed. Yet for the price, few have bested them in 20 years for sound quality.
In all truth, I intent my last good design in exotic wood and make them beautiful. This will also be a test of material , MDF vs. very rigid solid wood. Dimensions will be identical, so only construction and material will change.
A large amount of beauty can be had from design based on technological excellence. Form following function and all that. Of course when following that ethos one can end up with very ugly things too 😀
Then there's the designing products to look cool but then compromise on the engineering side of things. For example I've seen some see through loudspeakers that looked cool but didn't contain any damping material because it would obscure the insides...
If you can combine the two you're onto a winner.
Here are two matching Zenith console radios made in 1941. The field coil speakers and mounting boards are carefully stored in case the radios need to be returned to functioning. In their place is a pair of Hawthorne Silver Iris coaxial drivers. 150 WPC of vacuum tube power through 97 db 15 inch drivers is deadly loud and sounds quite nice aft les than rock concert levels.
Wow. That is simply gorgeous.
I know purists would give you grief about repurposing the radios, but at some point we have to realize that nobody is sitting around listening to a mono AM radio, and things are meant to be enjoyed. Yesterday I was commenting elsewhere that before electronics became mandatorily ugly, we had the unequaled beauty of art deco and cathedral radios.
Did you refinish those radios? Outstanding job!
I've always wanted to own any floorstanding Zenith radio.
I used to own a few floorstanding radios, and I can understand fully why you are using them as loudspeakers. They have a very definite superman voice to them. Something very authoritarian.
Anyway, here is my entry: (Sansui SP-2500)
