should I build this one?
front loaded 1segment horn, for 150hz 1000hz use.
loaded with b&c 12mh32 (i will use 4 of them).
Its my very first horn building so id like to understand howto not waste time,
these are the sims result:
I think your picture-links are broken
update. NVM. You just have to click them.
The design looks a lot like MT-130. I'll be following along - unfortunately I am no wizard at building cabs that go higher than 200hz 😛
Maybe you could try to smooth out the ripples and get some higher efficiency. 95 dB at the upper end of the pass band is low for a front loaded horn, it's even lower than this woofer without a horn.
What coverage angle do you aim for?
It doesn't look like your simulation is accurately describing your design. You should use the air volume inside the 12" cone plus the air volume within the 2 baffle rings combined, as your Vtc.
Secondly, take in account (or better simulate) the increase in SPL, due to the directivity of the horn, both on-axis as well as off-axis.
Johan
