Sounds like he needs a tumult and a crown k2 power amp 😀. Maybe you should wire the coils in series so he has a bit less power in that big a vented box.
What exactly separated from what? did the VC fall off the cone?
THe spider gets put under alot of stress during high excursion strokes. Its whole purpose is to stop the cone and begin to move it back in the opposite direction. Epoxy would work great. just make sure to scuff the metal area you plan on attaching it to. Rubber cement would work but it looses adheadin when things het hot. and since alot of hte heat generated by the motor is dicipated via the basket rubber cement wouldnt be the best of options. Superglue would work great. but justl ike the epoxy, scuff the metal before applying to ensoure pores for the glue to get down in and hold on to.
Be careful. Iron dust will zip into the air gap at the coil and you'll never be able to get it out. I wouldn't know how to do this safely with an energised magnet. It may not go in that easily but the potential for that to happen is great.
Hate to disagree with you CBF but isnt the purpose of the spider to control excursions? so that nothing moves too far? i thought it was the moters job of moving the cone frontwards and pulling it back.
CBFryman said:THe spider gets put under alot of stress during high excursion strokes. Its whole purpose is to stop the cone and begin to move it back in the opposite direction. Epoxy would work great. just make sure to scuff the metal area you plan on attaching it to. Rubber cement would work but it looses adheadin when things het hot. and since alot of hte heat generated by the motor is dicipated via the basket rubber cement wouldnt be the best of options. Superglue would work great. but justl ike the epoxy, scuff the metal before applying to ensoure pores for the glue to get down in and hold on to.
As I may recall, superglue does not work well with porous surfaces, read the side of the glue bottle before using it, it will tell you what it best. Also, make sure the glue will not react negatively with your spider's material, other it the part in contact with glue will get "eaten."
the spider has 2 jobs.
1. centering the voice coil in the gap so it does not rub.
2. providing a restoring force to the centeral position
BassAwdyO said:the spider has 2 jobs.
Yes, that is what i ment. once the motor stops pushing it isnt going to start pull untill it switches polarity completely (remember that music is AC) the Spyder keeps the voice coil from exiting the motor structure and keeps it centered along with stoping the voice coil. The surround Keeps the cone from swaying.
Had a similar experence with a tempest ,shiped all the way to europe, spent a day installing it ,and then discovered the loose spider
BassAwdyO said:providing a restoring force to the centeral position
I don't think so.
- Subwoofers
- shiva spider detached!!!
