what about ESPs 36db/octave subsonic filter
why not pump some sinewaves thru,grab a voltmeter,measure how much power is actualy going in,mite give u an idea.
P=VI
P=V^2/R
P=I^2 * R
🙄 and im about to finish designing my shiva 33hz basshorn...
i wouldnt tune a 12inch to 16hz and expect any output. id go 22hz or higher if it wont peak.
P=VI
P=V^2/R
P=I^2 * R
I'd shorten your pipe a bit and bring it closer to 20Hz.
You need a much larger radiating volume to get the effect of sub 20Hz bass anyway (a lot more than what 1 Shiva is capable of).
My Shiva is tuned to 22Hz without problems. I also recommend installing a port you can cap. If I have bass heavy material - I screw on the cap (airtight) to help control excursion further
Dave.
Dave.
