Shigaclone (rc-ez51) dead - help!
Hi.
I would appreciate some help and handholding hunting down the fault on this one. Last night I shorted something with my ring (one never learns 🙁) and after that almost everything is dead. Only the LCD and cd-door swich seems to work. It instantly gives 00 on the LCD. Holding the cd-door pressed it flashes -- and when released just 00 at once.
The motors are dead quiet - no movement or torque at all.
If I by hand turn the sled to activate the end switch and then press cd-door it continues to flash -- even after releasing the cd-door switch. Turning the wheel to get the sled outwards gives 00 when the end switch is released.
So that circuit seems to work as well.
How should I proceed to hunt this down? Maybe buy a replacement board if anyone have a spare? Then again it would be most educational to hunt it down with your help. And a good lesson for myself not to wear my wedding ring when doing electronics...
The obvious would be that the SCH69XH is blown? The woltages to the motors are all about 3.7... But again it could be steering...
Resoldered everything... Same as before - crap.
