shielded cables in enclosure
Billy,
You can connect both end to ground, however it has proven fact that only one end is needed for audio. If you connect one end of the shield to gnd and the other end to gnd with a cap you can introduce AC current noise currents into the shield.
All of this depend on the frequency of inside your. However realize that once your connected to a part, or the PCB you have no shielding, then your dependent on the layout.
Connecting the shielding at one end is done for audio frequencies and normally done at the source. However, you might find that it will sound different when connected the other way. You do not want noise currents flowing through the shield.
Shielding for high frequencies RF you connect the shielding at one end.
Shielding from Magnetic interference is done differently. You would use a shielded twisted pair, however the connection methods is are not stright forward.
Within a chassis, for low level inputs like phono or mic, I ground a shield or twisted pair ground at only one end, the amplifier input. If you ground at both ends, you have ground loops. I do connect the incoming ground to chassis, but via a small reslstor to chassis ground to break ground loops.
Balanced inputs would be far better, but they are typically not an option for consumer audio equipment. The phono cartridge or mic is already unbalanced.
