It is roughly the size and heft of uncooked udon, if you are familiar.
yes, i‘m familiar. i love the comparison.
thanks for your advice. i‘ve ordered a few different kinds and expect a shipment next week.
If this is for tube/valve amps, then there are a few comments worth making imho.
Many signal connections can be at high impedance nodes, where stray capacitance from the shield may be an influence, especially for hi-fi related amps where extended bandwidth may be mandatory. Eg. for a Williamson style amp - the layout-layout-layout mantra should mean no use of shielded cable.
A shielded cable run still needs to be as far as practical from any disturbance field as possible, with the shield mainly attenuating pickup from any nearby high voltage signals (eg. mains AC, output stage driver and plate, heater and output wiring). The typical applications I use it for are to connect valve socket nodes to front panel pots, and output signal feedback.
For guitar type applications, I just recycle my now unused collection of RCA/video/scart shielded cables. Even then the cable length may become a concern. If you are keen, it can be worth measuring the capacitance of interconnect cables, as capacitance per length can vary quite a bit - and just use the lower capacitance/length cables.
I rarely would use the shield for a ground path, and if you're concerned about tidiness or stray screen strands, then some heatshrink over the un-connected end of the shield may appease.
I would not normally contemplate shielding any signal line that was above DC ground, and especially output stage screen and plate signals - they would require a good understanding of many aspects of the cable you would need to use.
Strain relief cords or wires in cables are there to allow the cable to be pulled through a duct.i just received a shipment of cables. mogami 2330 among them which has a "silk strain relief". do i cut away the silk when i strip the cable or just keep it there while soldering?
If you can solve a RF or mains hum pickup only by using shielded cable inside the chassis, there are big construction problems. You have to solve those first.
did i say that i have those problems? i thought it was good practice to use shielded cables for signal wiring inside the chassis.
Mixi it would be good to post how everything worked out for you.
I’ve found it to be good practice after asking the forum for guidance to post updates, photos, preferences etc. to 1. Help others who come upon the thread who are in a similar boat 2. Make those who have contributed feel their input has made a difference.
I couldn't agree more. Thanks for reminding me. Unfortunately so far I've only had time to try the Mogami 2330. I'll post my impressions and findings as soon as I've worked with the other cables I ordered. I hope to find time for it next week.
Thanks for your help so far,
Michi
Let it go man, you are deluding yourselfUnfortunately so far I've only had time
- Design & Build
- Construction Tips
- Shielded cables for wiring inside chassis
