Flushed with the success of replacing capacitors with mainly Pan FC (and Rubycon ML where I couldn't get Panas), I wondered about the power supply caps. The originals are 6 off Jamicon 4700 uF marked '831 KO (M)'. As far as I can make out Jamicons seem to be used in car radios, so the question is - would substituting these for alternatives show a marked benefit? If so, in what areas? There are space constraints, these caps are 30 dia x 30 height. I could go to 40 height maximum to fit in the case.
I'd be really grateful for others' views before I delve deeper, all suggestions welcome!
Ron
Ron
I know there aren't too many of these amps around, but as a general principle would you think I'd get much benefit from changing the smoothing caps?
