sharp qa 1650 black and white issue fixed
i'm starting this new thread because some of the old threads addressing this issue are old and tend to fall away from the subject. just in case anyone is interested, i think i've found a temporary solution for the black and white problem after searching the forums. i found a contrast mod, and thought, well, i might as well try it. it worked, so- so. then i got to thinking that the color problem may be able to be fixed the same way, so i was looking at the video card and i noticed two resistors right above the s-video port. i assume, since s-video has four pins: 2 grounds, one for picture and the other for color, that these two resistors control picture and color. so i got out a little flathead and gave the one on the right just a little turn and i get color. the only problem with this is that i have to give it a little turn everytime i start the projector up, but my top is hinged anyway, so no big deal for me. if anyone has any other insights as to a better way to solve this problem, i'd be glad to hear them, but in the meantime, i hope ths helps anyone with the same problem.
