Im not sure where to post this, but im posting it here.
I just got a sharp projector on ebay for about 110bux including shipping.
i thought that it was very cheap, but i see why. the specs are here:
http://www.projectorcentral.com/Sharp_XG_Series-XG-E850U.htm
he said it comes with no bulb, as the old one died.
is there any way to beef up the lumens? or another method for a bulb, because its like 340 dollars! im not paying that for a bulb. i want to get like a higher wattage halogen for more lumens.
any ideas? the projector works fine.
have u got any internal pics of the projector with the cover off? u can retrofit it out with a cheaper metal halide bulb but we will need to see if u have enough room for it, the older bulbs in these things wearnt as bright as they are today and the optics also are of not quite a high state as the newer models so to beef up the lumens id give it a darn good cleaning on the optics maybe change a few things like condenser ect and retrofit it out with a 250w mh system, until i get to see inside of this thing i cant help u anymore .
Trev
Trev
ok. once the packege gets here, i will take pictures of the inside.
its as big as a slide projector.
anyway, the bulb slids in directly in the middle of the back. according to pictuers i ran in on ebay.
Thats kind of pricey buddy, u should be able to get a working one for that price. I got an infocus lp220 for $60 it works, missing lamp and projection lens, it would probally cost me about 150 to get it going again with a 12khr bulb retrofit. Im looking at rebuilding it into a new case so im holding off on that for now.
Trev
Trev
no, thats not the auction i bid on.
i only posted that for the pictures.
i bid on an auction, for the projector which was 110 dollars.
but the bulb is outrageously expensive. about 409 dollars.
i was wondering if there was of any way to make a different preferably alot cheaper bulb to work with it?
Here is the one I bid on: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3064763867
know a source for cheap bulbs? its awful lousy that a 250W bulb is 400 bux.
the problem is, the projector doesnt come with the cage either.
i was wondering if the ballast is on the cage.
i wonder if a 350 or 400watt halogen would work? that outta kick up the lumens, as soon as i figure out how bright 175 lumens are.
now thats more like it lol, ok forget halogen in one of those, the halogen just are too hot, it would have to be a metal halide light, id say if u got enough room go for a 250w hqi lamp and if not maybe the cdm-t will work, the lumens i wouldnt worry about too much, the more lumens u have means its more watchable in a lightend area although 175 is low i must admit but its watchable, i would be very suprised if u dont get 175lm with a cdm-t bu;b in that.
Trev
Trev
well, i dont understand bulb technology that well. even though im an electronics tech.
Got a link to cheap bulbs? or a link to a bulb site with good prices?
thanks.
thanks.
ya have a look in here under cdm-t and hqi 250w
http://www.productionadvantageonline.com/lamps.htm#METAL HALIDE LAMPS
no probs being a techy and not knowing about bulbs , this is the electritans stuff anyway
Trev
Trev
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- Sharp LCD projector modification question
