If worst comes to worst and you cannot figure out enclosure volume, fill a gallon jug with water or sand or etc, whatever works best and will be safe on the box. This is a last-ditch guestimate. You could even use cups lol.
purplepeople said:Okay then, doesn't a passive radiator remove that first reflection by deflecting in response. Could you then use a PR in a "thin" box?
Except that at the frequencies of particular interest the PR behaves pretty much like a cabinet panel.
dave
Here's a skinny sub
I don't need one of these but I thought it was nicely done.
http://www.partsexpress.com/projectshowcase/boogieman/design.html
pedroskova said:Boston Acoustics' first designs were quite shallow. The A100 was aprox. 20" wide x 30" high x 8" deep. Tthe A700(?) was about 50% larger while retaining the 8" depth.
Even more radical was an early Duntech design, the PCL-somethingorother. It was ~ 12H x 24W x 3D, and was designed to be hung on a wall...great sounding little speaker.
In both cases, the designers pointed out the elimination of early reflections as one of the main design goals.
The early Bostons (A200, A150, & A100) are still considered excellent sounding speakers too. The wide & shallow baffle was unique at the time but was moved away from early on to more conventional designs. WAF was one reason. It wasn't because of how they performed.
I wonder OP actually did this experiment: build a proven closed box, and then convert it to a shallow & wide version maintaining same volume. How much the sound would be affected? It would be great if anyone actually measured it.
The OP wanted to know if there's performance difference if same units and crossovers are packed into a conventional closed box or a wide and shallow box with same volume. I don't know how a ceiling/wall-mount units apply to this thread.
I always wanted to build these but never got around to it.
Tom Zurowski PAWO Rear Loaded, Wide Baffle, Side Venting FR125S Horn
- Shallow Speaker
