Shaft adpater ideas for input selection and volume?
So I ordered an enclosure from www.diyenclosures.com and it came with knobs with large holes for the shafts, but the volume knob I ordered, the Panasonic EVJ-C20, has a smaller shaft, and the input selector, a Grayhill 56D30-01-2-AJN, has a ridiculously smaller shaft.
Does anyone have any ideas or suggestions?
I don't have much information as far as measurements right now since I'm at work. Also, I can't remember the enclosure manufacturer.
Here's the parts I ordered:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P2T3103-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=GH5602-ND
Make your own extender rods from aluminium rod the same diameter as the knob holes (probably 6mm or 1/4 inch). Then carefully file the other end to the same diameter as the shafts on the pot and selector. Then make up a connector to join them together.
Or - buy another vol control and selector with the same sized shafts as the knobs. 😉
