sex bolt/mating screw for torroid fixing
You MUST avoid the shorted turn.
If a metal bolt touches the yop and bottom of the case, assuming it is a metal case, you will destroy the transformer.
If the transformer is that tightly fitted into a case then you must use somrthing that does not complete the "turn" inside the transformer. ie a Nylon bolt.
M6 nylon stud is pretty commonly available.
thanks for that. I might try a m6 nylon spacer with two bolts 😱
