I've been building a 6L6 PP amp for the past few months. I finished it a few days ago, checked out all the points for correct voltages, etc. But as soon as I plug in the output tubes and turn it on, I hear a loud buzzing at the OPT's (Hammond 5k 30w). The frequency differs for each channel, and changes if I switch the tubes.
I went into the circuit and saw that with the output tubes in place, I measured an oscillation at the output tubes' first grids (after R9 in the schematic). So I thought that it must be coming from elsewhere in the circuit. I took the output tubes out and measured again at the same point. No oscillation.
Now I thought it must be bad output tubes/incorrect OPT wiring. Re-checked the wiring, and it's fine. Ran the output tubes without the 6SL7 inputs: no oscillation.
Now I'm thinking it must be R15, the feedback resistor. I measure at the output: no oscillation. I don't get it.
The schematic is attached.
Hello!
Try to swap the output transformer secondary connections: swap the grounded wire with the one to the feedback resistor and see if it cures the oscillation.
Something that happenend to me at least once: check if you have connected each UL tap to the screen grid of the PROPER tube. I sometimes swap then and heavy oscillation occurs.
A note about the amp design: please note that C5 isn't absolutely needed at all 😉
Remove R15 temporarily and run with reduced input to troubleshoot. If removing R15 solves the problem, then reverse your leads on the output of the OPT.
Giaime makes a very good point about the U.L. taps.
You need C5 when the amp changes from class A into class B operation.
poobah said:You need C5 when the amp changes from class A into class B operation.
Just forgot of this. Too into "audiophile class A" kind of stuff.
My last one was just a week ago... did you remember poobah? I swapped the anode caps of the two tubes of a push pull
Yes! And someday, you will try to build an oscillator... for real... and then it won't oscillate!
Ok, trying to remove R15. It's very difficult to make changes now because I insulated everything very well (all covered in heat shrink and tape). My father decided to come to my aid and tried to measure the resistance between the cathode of VL1.1 and the hot output. Naturally, he got some strange number (768ohms), and told me to check R15 again.
poobah said:Yes! And someday, you will try to build an oscillator... for real... and then it won't oscillate!
You read my mind. In fact some time ago I had some defective 555s that didn't oscillate 😀
Well, removing R15 allows you to divide and conquer. Your feedback, through R15, could be negative (good thing) or positive (bad thing - oscillator). This all depends on the polarity of ypur OPT secondary... very easy to get it backwards!
With R15 removed you can rule out other causes of oscillation.
dmitriy167
768 ohms for R15 sounds about right. Remember both sides of R15 have a path to ground.
Path 1 -> OPT secondary.
Path 2 -> R5 1k.
That's because you've removed or opened the NFB path.
First I would do as poobah suggested. leave all the tubes in place and disconnect one side of R15. If the oscillation stops swap the secondary connections i.e. R15 and ground. Power up the amp (with R15 connected) and if the oscillation is gone...hooray!
Cheers
Wayne
Path 2 -> R5 1k.
Ran the output tubes without the 6SL7 inputs: no oscillation. Now I'm thinking it must be R15, the feedback resistor. I measure at the output: no oscillation. I don't get it.
Cheers
Wayne
I just switched the OPT output leads and it works fine without oscillation! Thanks guys, you helped me out with that! Let me just hook a speaker up and see if there are any other problems...
please pull up to the second window!
poobah is that the one with the Macarena music? 😀
Wayne
...And here we have some noise. A .01uF capacitor from input to ground seems to fix the problem.
Also, the gain is low. With 6L6WXT+'s that I'm using, I'm expecting quite a bit of power. I'm getting only one or two watts with my CD player all the way up.
The gain of the circuit you posted looks low to begin with. Try increasing the value of R15 to 5.6k -> 10k or so.
Wayne
PS this will upset the bias on VL1 somewhat. So after choosing a new value for R15 you may have to decrease the value of R5 accordingly 🙂
Wayne
The noise is coming through both sides. It's a 60Hz buzzing sound. I checked it on the scope, and it's a wave with small high-frequency peaks, nothing else. If I place a 0.01uF capacitor from input to ground, it's gone. So I'll just solder those caps in and no more noise.
From the input signal (HOT) to ground or input ground to chassis ground?
Do you live close to a TV tramission tower? Could it be 30Hz? The reason I ask is that it could be RFI. Check your grounding scheme.
Placing a 0.01uF across the input is not a good idea. That's 10,000pf of input capacitance! Your HI's will most likely suffer greatly! OTW you've made a low-pass filter.
Wayne
- Tubes / Valves
- Severe oscillation in 6L6 amp
