Several steel chassis and covers for sale in South UK
1) Chassis for a project (valve amp or radio). This is a folded and welded bare steel chassis, professionally made. Dimensions are (+/- a couple of millimetres): 386 x 260 x 93 mm with a 21 mm lip on the bottom 1.4 mm thick steel. Heavy. Not drilled or punched. Minor rust marks in places. With base plate. £15 collected.
2) Chassis for a project (valve amp or radio). This is a folded and welded steel chassis, professionally made. Dimensions are (+/- a couple of millimetres): 410 x 138 x 62 mm, I forgot to measure the lip, ask if this is important, 1.5mm steel. Heavy. Not drilled or punched. Minor rust marks in places. £10 collected.
3) Two half chassis. Folded steel “J” shaped to form up to a square tube (no end panels) 340 x 380 x x57 mm. One has a 75 mm diameter hole in the middle 70 mm from the long face and some cuouts in the "front" face (see photo 6). 3.25 mm thick steel! Heavy. Minor rust marks in places. £10 Collected.
4) Two steel covers. These are “U” shaped with stiffeners/flange and louvres. I forgot to measure these but about 4” x 4” x 12” (I’ll measure if any interest). Heavy. Some small holes near edges. One is black crackle finish and the other black matt, £10 collected the pair.
Any and all can be collected from Battle near Hastings in 1066 country most days or early evening. They are quite heavy so will absorb a lot of vibration.
I can deliver in the Eastbourne/ Hastings area for petrol costs. E&OE.
Reactions: Grarea
