Setting switching frequency on IRS2092 chip. Does this signal look a little strange?
The datasheet calls for it to be adjusted to 400kHz and out of the box this china board was set at about 100kHz. I now have it adjusted to around 300kHz but the signal looks strange I think. Is this off track?
It's not the sine wave I'm concerned with. I realize it's supposed to be there and adjusted to 400kHz, but the strength of the signal is increasing and decreasing... i.e. not a steady 2V p-p signal. The sine starts at say 1v for example and goes up to 3v. Seems like it should hold at a steady AC voltage. It does this when I turn the frequency down. But if I turn it up closer to specification, it starts to fluctuate pretty bad. It's inautdible of course since it's such a high frequency so no problem hearing it, but I wonder if it should fluctuate like this. As mentioned, it holds a steady AC voltage at lower frequencies. It's when I turn it up that it starts to become unstable.
