Servo Drive Sub woofer
I'm curious if there is a plan or schematic for a servodriven woofer. I'm talking about one that actually uses an actuater attached to the cone to get the push/pull motion. I also wonder about parts.
I know that a company called Servodrive builds subwoofers based on this principle. My idea is to experiment with this design with smaller speakers 10" and 12" and use them in full range 3 way cabinets.
Does anyone know where I can find drawings and parts for this type design? I confess that I'm a real newbie at this and my knowledge and experience is limited at best and is closer to non-exisistant.
Thanks for your replies and help. 🙂
doesnt the servodrive website have a drawing? if not, basically it works on the same concept as an auto engine's piston in reverse. you're converting rotation into pistonic movement.
While rotation is harmonic in 2 dimensions, pistonic is only harmoic in one. I believe the motors' armature actually twists one way then the other in this design and thus requires a low inertia moter.
I want to try a design using a flywheel and a piston system to make high intensity infrasound where the motor continuously turns.
