Service manual of INT-30A
Offset is fine/not alarming.
For Iq you can measure DC voltage drop across a few of the source resistors on either OS, and post here. Wayne will be able to tell whether or not it is in the ball park or not. As will others.
Regards,
Andy
As far as I know, there is no industry standard for DC offset. The lowest possible DC offset is always recommended.
Each manufacturer has a set up procedure in their service manual and it is highly recommended to check and set it up.
You should know that.
I was thinking there was a short write up somewhere about this "intentional" DC offset and it's effect on distortion. But I can't find it now. I've mentioned it before, but normally I'm smacked on the head by the "DC offset can only be 0.0000mV dum dum!" crowd...
A DC voltage offsets shifts the voicecoil position up or down, so distortion reduction really depends on the rest position the coil, and the symmetry of the Bl curve. There are assembly tolerances for loudspeakers so there are inherent variations in the rest position and Bl curve.
Worrying about a few mVs of DC offset is a fool’s errand unless you work in a laboratory.
Hello.
End of story. After corresponding with PASS USA, I obtained the exact BIAS settings for the L and R channels for the mentioned piece and set the Differential offset and Absolute offset values after warming up to operating temperature.
That's all, thank you.
With that, I would like to close this topic.
