Hi
My 3582A descided to quit on me.
Text shows up and i can see that signal comes in on clipindicator.
But no readings on display.
Anyone with a service manual willing to share ?
Looking forward to any help in the matter.
I have the operators manual.
What i need is a repair/service manual or at least a schematic.
Thanks for trying to help.
Odd that Agilent doesn't offer the service... As I recall the 3582A was one of those analyzers that had the combo digital / analog display that were such a pain to work on. Look on the back for a video out and see if your signal is present there. If so look for a manual for the display itself. It has all sorts of self tests on it. As long as you have any clear characters on the screen it's fixable. If the CRT or HV goes, it's toast. I've got some boards from a couple I could maybe dig out if you run into parts problems.
Doc
Doc
The person i talked to at HP considered the unit old and i wasn´t a prefered big money customer.
I suspect that some kind of amplifier card has died.
The input section is working cause i can see the overload leds going on/off if i switch range.
The display lights up and text is working but no measuring beam is showing up.
I´ll try and rip it apart for optical inspection.
Perhaps a bad connection or solder joint further inside on the backplane.
As I suspected, it does appear to be one of those units that uses the HP digital display. (Also the 3562A dynamic process analyzer). The display unit itself is an HP1345A and op-service manual is available for free download from Agilent. If you don't have it, you should get it. As the display itself has a number of self tests.
Doc
Technical Support: 1345A 6 INCH DIGITAL DISPLAY [Obsolete]| Agilent
Doc
The 3582a has a bigger display then the 3562a at least the part thats visual.
Thanks for the link has to pull it apart tonight.
I´ll post the findings when apart.
With the help of a member i´m now in possesion of a complete service manual.
I´m always impressed by the good spirit and helpfull members of this forum.
Fault hunting starts after dinner 🙂.
For those others who may have one:
http://www.a0101.com/upfile/03582-90000.pdf
Dang, scratch that. Just another op manual.
I´m slowly working through the cards in the 3582a one by one.
It´s old, the components scream vintage 😀.
So far no obvious disasters, a card riser would have been nice though.
I'm in need of a service manual for one of these too. These likely have their share of marginal electrolytics after 30 years. They don't look so old on the outside, but add 1960 to the first two digits of the serial for the year. It never hurts to check the power supplies first although that reminds me of the old joke when a passerby asks a guy crawling on the ground by a street light what he's doing.... looking for keys is the reply. When asked where he lost them he says down the block and is then asked why he's looking where he is. The light's better! Last I checked my old HP 300A Harmonic Wave Analyzer, close to twice as old, is still working. That makes this newer stuff with proprietary chips that come and go look like a passing fad. But old or older, HP gear is great stuff.
After some digging i found a couple of bad caps, some resistors that looked like they had a hot time was replaced to.
It´s now up and running again.
It´s a very solid buillt piece of equipment will work many more years.
Thanks to all help from members of the forum.
I just bought a HP3582. Unfortunately, looks good but does not work. We saw above that someone has service manual for the analyzer. Please ! can anyone to send me this service manual ? Maybe I'll be able to troubleshoot it.
Thank you,
niculian (nicu_balica@yahoo.com)
Thank you,
I find service manual here: http://www.ko4bb.com/Manuals/HP_Agi...HP_3582A_Spectrum_Analyzer_Service_Manual.pdf
if someone with experience in this area, please contact me by email, I need advice
Thank to all
Thank to all
- Design & Build
- Equipment & Tools
- Service manual HP 3582A
