Hi there,
Does anybody know where I can download the Aleph30
service manual? All the references I've found pointed
to the Volksamp site, which is no longer operational.
I also couldn't find it on the passlabs.com.
Many thanks,
Dennis
P.S. I'm a newbie who's lurked around for a little
while and have been amazed at the amount of information
available here. Hope to build an Aleph 3/30 in the future.
Many thanks,
Dennis
Dear Mr. Pass,
Thank you so much.
Dennis
Thank you so much.
Dennis
Nelson Pass said:Mr. Harrington will move it over to the www.passlabs.com
site in the next couple of days for you.
Building the Aleph 60
I've looked at the schematics of the Aleph 60 and it's quite similar to the Aleph 2. I am planning to build the Aleph 60 as the 60W is quite sufficient for me with lower heat dissipation. I would be grateful if someone could help me with the following:-
a) I noticed there are two resistors R1 and R8 in the A60 which
is not in the Aleph 2 and the values of these were not given.
Are they necessary?
b) The output of the mosfets are connected to the speakers thru
6 pcs of paralleled 3 watts 1R resistors giving a final
resistance of about 0.17R. Could I just use a non-inductive
resistor of say 0.15R in a 20W TO220 package by Vishay,
meggit, Mills etc?
c) For C17 in the balanced input, could I use a film and foil cap of
say 20uf to 40uf instead of an E cap of 220uf? Would this
affect the bass response?
ckt
Are they necessary?
meggit, Mills etc?
ckt
a) R1 and R8 are trim resistor to get the last bit of
DC offset and PSRR. There is a thread elsewhere on
this site that you can search for.
b) Yes
c) Yes and Yes.
b) Yes
c) Yes and Yes.
