I'd like to know if there are any advantages of having separate left & right volume controls on an audio amplfier opposed to one volume control for both channels. Are there any sonic or audible differences? Thanks.
sure, if you want better channel seperation and/or like to have the option of adjusting left/right volume without adding a seperate ballance control. Besides you get a few more types (of pots) to chose from.
The only hastle is adjusting the volume with the two channels following properly. It requires the two pots mechanically linked, no big deal, but adds a bit in building complexity.
Hello PTL60,
I had a power amp with Alps laser trimmed stepped 21 position vol pots on front panel.
The attenuation was 0dB at full clockwise rotation (with CDP connected directly this gave only momentary and inaudible clip),
coming down in 1 dB steps to -20 dB, then mute.
This provided a stunningly transparent system, with the volume level perfectly settable and repeatable in 1 dB steps.
Separate infinitely variable pots are a straight out pain, but a pair of stepped attenuators works great ! 🙂
The big advantage here is that you have close matching of L&R gains, and this is quite critical for correct imaging.
It is too hard to set the gains easily with L&R pots, and most dual pots give pretty lousy L/R channel matching.
Hope this helps you,
Regards, Eric.
BTW - despite what some old textbooks say, a level change of 1 dB is perfectly clearly audible.
Regards, Eric.
Hello Eric,
Thanks for the info. I've heard about stepped attenuators, but aren't they quite expensive?
Hello PTL60,
Of course this comes down to a value judgement, regarding your audio system.
I do not have much experience with rotary switch stepped attenuators, so other constructors on this forum may have some better knowlege and comments on these.
The key factor in all of this is close channel matching, and this is the only proper way to get it.
Hope this helps,
Regards, Eric.
The ALPS stepped vol pots are not too expensive, but yes some DIY attenuators using high quality rotary switches and Holco or Vishay resistors can end up pretty pricey .Thanks for the info. I've heard about stepped attenuators, but aren't they quite expensive?
Hope this helps,
Regards, Eric.
Hey Eric,
Do you have a source/model number for the Alps? I didn't think they made these any more. I used some maybe 20 years ago, and if suitable values are available at a good price could be useful for a couple of projects I have running.
TIA
TIA
Hello Brett,
The pots were original equipment in this amp 10+ years ago.
I have been to http://www3.alps.co.jp/index-e.html but a quick look didn't show them.
http://www4.alps.co.jp/pdf2002/pdf_e/metalshaft/50mm.pdf looks interesting. but price ?
Any body have a review of these ?
An english company was advertising the alps blue pots a couple of years ago in Electronic World magazine - I'll find out for you.
Regards, Eric.
Regards, Eric.
- Separate Left & Right Volume Controls
