is it a good idea to build a separate chassis PS for the UcD amp?
then use as short as possible (~150mm) 12g wires with CPC connectors to link the two chassis together (PS & amp chassis)
there can be some really good benefits of having a separate PS.
How short is the connection from the output of the filter caps to the power input of the UcD module should be (any specific figure)?
thanks,
onixuser
thanks,
onixuser
I don't think a separate chassis is necessary if your layout is good.
Joined 2002
