Oh, I misunderstood! Monday 5:30 okay? Thanks Dave!
OK, i now have a deadline to get the drivers back in the boxes.
dave
Allegro is an interesting compact design that appeared in the German Magazine Klang & Ton.
It uses the Ciare HX160 fullrange driver as a widerange unit coupled with a tweeter.
Link (in German):
http://www.lautsprechershop.de/hifi/allegro.htm
91db sensitivity is pretty ok for a 380 x 250 x 280 mm speaker
Link (in German):
You could clone the Decware DM944/945. 94dB 1w/1m, 4 ohm impedance and has pretty decent bass response. I owned the 944 for about two years and quite liked it on most music using a SS integrated amp.
I think I'll order a pair of FF165WK. How far are your beta plans?(...) FF165wk would be the most efficient in a bookshelf size(...)
5-9 litre reflex would be good. My boxes for these are under development or in beta.
dave
(And if not (?), which of the small Fonken plans would you recommend for them?)
Just a thought - I built a pair of bokkshelf/near field speakers from a design by your countryman, Henkjan. These used the Alpair 5 drivers in a transmission line. For 2" cones, these go load and low, and can easily be augmented with a small sub, if required.
... for a box 5-7 litre you need FF125wk. I haven't figured out how small a box needed for FF165 ... likely on the order of 2x the volume
FF125 plans need just a tiny bit of work and they can be purchased. Betas turned out well, but pointed out some necessary fixes in the docs.
The large 165 box is at the beta stage
dave
I find it curious that no one has mentioned the Tang band full range drivers. The 4" bamboo one is plenty efficient enough to be driven by 12 watts in a small to medium room and they are inexpensive. I believe that a 1.25 (liter/cubic foot?) transmission line cabinet would work but I may be remembering the wrong driver specs. Here is something to look at:
http://sketchup.google.com/3dwarehouse/details?mid=1295d67f38bc99be790962a403b469d
Ahh, OK. And for the FF125wk, I use the FE127e mFonken 1v1 (milliFonken – 4.5 litre vented) or the FR125S miniOnken 1v0.1 plans, right?... for a box 5-7 litre you need FF125wk. I haven't figured out how small a box needed for FF165 ... likely on the order of 2x the volume
dave
Do these use "just a capacitor" as the Xover? If so an interesting option to clone. About $240 for drivers currently.
from Decware specs:
SPECIFICATIONS
94 dB with 1 watt at 1 meter42Hz ~ 22kHz
available in 4 or 8 ohm nominal impedance
Crossover - 6dB Clarity Cap on Ribbon only
2 ~ 25 watts continuous, 100 watt max
Max SPL 112dB
I couldn't find details as to the XO point, so you'd have to guess the best point depending on your drivers of choice - a paper coned mid-bass that rolls of smoothly on the top end anywhere from 3-5K would certainly simplify things .
AFAIK, most of the lower cost eligible ribbon / planar isodynamic candidates like to run from around 2500 / 3000 up
chris, I did find that...
I looked into the drivers fairly closely. The Decware site indicates that the 8" mid-woofer is a Silver Flute wool coned driver. Based on the indicated impedance, it should be the W20RC38-04. Looking at the tweeter it looks like a Swans or HiVi unit. The closest I could come was the HiVi RT1C-A tweeter, currently on sale from USD $120 ea. to $80 ea. The Silver Flutes have a regular price of USD $40 ea.
dheming, do you recall...
Maybe you can recall the cap used as a tweeter, and was that all there was on the tweeter?
from Decware specs:
How do you get 94 dB out of a 91 dB driver?
The 4 ohm is 93.7 dB sensitive, but thats 2W in...
With the silver flutes the XO looks like it would need to be about 6k XO, that ~4dB peak at ~4k is nothing to write home about either,
Ryan has some real-world experience with the SF W20, (hey you listening Ryan?)
dave
... The closest I could come was the HiVi RT1C-A tweeter, currently on sale from USD $120 ea. to $80 ea.
$80 at PE. Looks about right sensitivity wise to mate with the 4 ohm SF W20, with just a cap. Maybe a bit higher than 6k to help exacerbate the W20 peak.
dave
well, don't underestimate the power of Zen thinking / market-speak
or he could be using different drivers
We are pretty sure that the SF have been confirmed from multiply sources
The wool cone 8 inch driver gives stunning weight behind a glass smooth mid-range and this is complimented by the air and shimmer that is only found in ribbon tweeters.
And given the above, it is a Siver Flute, and unless a special OEM version (did Steve buy 1000+), pretty much nails it.
dave
The older DM944 does indeed use the 8" Silver Flute 4ohm woofer. The HiVi RT1C-A is crossed in at around 8kHz via a single 3.3uF metallized film cap in series.
Thanks for the email ping Dave.
Yikes. I would not run that woofer past 2khz max. The experience I have is with the 8ohm, but they're identical afaik. Mine also has a nasty break up around 4khz. It's loaded with distortion and bad decay. I'm on my phone, but I'll post FR plots a little later. They're outdoor measurements and pretty reliable I think.
- Full Range
- Sensitive bookshelf speakers for Tripath
