What's the best source impedance for the Sennheiser HD800 headphone? Best means: 1) what's the source impedance indicated by Sennheiser? 2) What's the best experimental source impedance for a correct balanced sound? Bye Francesc0
There is the nominal impedance (300 Ohm), but I need the suggested optimal source impedance ( i.e. the best output impedance for the amp). Thank you Francesco
Are you shure? Some body sais that the sound is to much brilliant in that way. I know that loudspeakers need 0 Ohm source impedance for hi dampening. But it seems that headphones are "tuned" differently. The standard is 120 Ohm, but what for HD800? Francesco
